Copy the devicetree source for the A10s/A13/GR8, A31(s), and A23/A33/R16
SoCs and all existing boards from the Linux v5.18-rc1 tag.
These changes are combined into one commit due to interdependencies:
- The unit addresses were removed from bitbanged I2C buses, which
drives a Kconfig default change. This affects sun5i-a13-utoo-p66.dts
and sun6i-a31-colombus.dts.
- The pinctrl nodes were renamed, including some used by the shared
header sunxi-reference-design-tablet.dtsi.
To maintain ABI compatibility with existing LTS kernels, one change
moving some IP blocks to the r_intc interrupt controller is excluded.
This effectively reverts Linux commits 994e5818392c and 9fdef3c3d8c2.
This commit renames the file sun8i-r16-nintendo-nes-classic-edition.dts
to sun8i-r16-nintendo-nes-classic.dts to match the Linux tree.
This commit also adds the following new board devicetrees:
- sun5i-a13-licheepi-one.dts
- sun5i-a13-pocketbook-touch-lux-3.dts
- sun5i-gr8-evb.dts
- sun8i-a23-ippo-q8h-v1.2.dts
- sun8i-a23-ippo-q8h-v5.dts
- sun8i-a33-et-q8-v1.6.dts
- sun8i-a33-ippo-q8h-v1.2.dts
- sun8i-r16-nintendo-super-nes-classic.dts
As with the other SoCs, updates of note are conversion of GPIO pull-up
from pinconf to GPIO flags and renaming the detection GPIO properties in
the USB PHY nodes.
Signed-off-by: Samuel Holland <samuel@sholland.org>
Update all A31/A31s devicetree dtsi and dtsi files from
Linux-v4.18-rc3 with below commit:
commit b240b419db5d624ce7a5a397d6f62a1a686009ec
Merge: 9c2dd8405c0c 518d2f43c358
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Thu Apr 5 21:18:09 2018 -0700
Merge tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Sync dts files with the current (Aug 18th 2016) state of Maxime's
linux/sunxi/for-next repo.
Note this commit also updates configs/MSI_Primo81_defconfig,
adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary
because the tablet does not have a reachable uart so the dts sync
drops its serial0 alias.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Sync the sunxi dts files with the changes queued up for kernel-4.3 in
mripard's sunxi/dt-for-4.3 branch.
The Mele A1000G-quad and the Mele M9 have the same PCB, sofar we've been
using the same defconfig (and dts on the kernel side) for both models.
Unfortunately this does not work for the otg controller, on the M9 this
is routed to a micro-usb connector on the outside, while as on the
A1000G-quad it is connected to an usb to sata bridge.
This commit adds a new defconfig for the Mele-A1000G-quad to allow using
different otg controller settings on the 2 boards.
