path: root/arch/arm/dts/sun5i-a10s.dtsi
2018-09-28ARM: dts: sun5i: Update A10s/A13/gr8/r8 dts(i) files from Linux-v4.18-rc3Jagan Teki
Update all A10s/A13/gr8/r8devicetree dtsi and dtsi files from Linux-v4.18-rc3 with below commit: commit 190e3138f9577885691540dca59c2f07540bde04 Merge: cafc87023b0d a7affb13b271 Author: Arnd Bergmann <arnd@arndb.de> Date: Tue Mar 27 14:58:00 2018 +0200 Merge tag 'sunxi-h3-h5-for-4.17' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/sunxi/linux into next/dt Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-08-26sunxi: Sync dts files with upstream kernelHans de Goede
Sync dts files with the current (Aug 18th 2016) state of Maxime's linux/sunxi/for-next repo. Note this commit also updates configs/MSI_Primo81_defconfig, adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary because the tablet does not have a reachable uart so the dts sync drops its serial0 alias. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-07-24sunxi: Enable NAND controller on the CHIPBoris Brezillon
Enable the NAND controller in the sun5i-r8-chip.dts. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sun5i: Sync the DTSI with the kernelMaxime Ripard
Add the latest kernel changes to the sun5i family DTSI. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-09-10sun5i: Add A10s-Wobo-i5 defconfig and dtsJelle van der Waa
The Wobo i5 top set box is a somewhat curious A10s based top set box, it uses an AXP209 rather then the AXP152 usually used in combination with the A10s. It has an ethernet phy connected to PORTD rather then PORTA, and its built-in usb wifi is connected via the otg controller. The dts file changes are identical to the changes submitted to the upstream kernel. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-06-04sunxi: Sync dts files with the linux kernelHans de Goede
Copy over all the latest dts changes from mripard/sunxi/dt-for-4.2 , this gives us a proper dtsi file for the A33 rather then abusing sun8i-a23.dtsi for this. And this replaces our minimal (dummy) sun7i-a20-mk808c and sun8i-a33-astar-mid756 dts files with proper ones. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: dts: Sync all dts files with upstream kernelHans de Goede
Bring all the sunxi dts files (and update existing ones) from mripard/sunxi/dt-for-4.1 (which will be merged into upstream master any day now). This is necessary so that we can move all sunxi boards over to the driver model. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
