path: root/arch/arm/dts/sun5i-a10s-wobo-i5.dts
2016-08-26sunxi: Sync dts files with upstream kernelHans de Goede
Sync dts files with the current (Aug 18th 2016) state of Maxime's linux/sunxi/for-next repo. Note this commit also updates configs/MSI_Primo81_defconfig, adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary because the tablet does not have a reachable uart so the dts sync drops its serial0 alias. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-09-10sun5i: Add A10s-Wobo-i5 defconfig and dtsJelle van der Waa
The Wobo i5 top set box is a somewhat curious A10s based top set box, it uses an AXP209 rather then the AXP152 usually used in combination with the A10s. It has an ethernet phy connected to PORTD rather then PORTA, and its built-in usb wifi is connected via the otg controller. The dts file changes are identical to the changes submitted to the upstream kernel. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
