path: root/arch/arm/dts/sun50i-h6-orangepi-one-plus.dts
2018-11-13arm64: allwinner: h6: Add common orangepi nodes into dtsiJagan Teki
Based on the information from hardware schematics and orangepi vendor orangepi H6 boards, One Plus and Lite2 shares common nodes like axp805, uart, mmc0 etc. The common differences between them is - One Plus, has Ethernet - Lite2, has Wifi, USB3, CSI port. So, add common orangepi nodes into sun50i-h6-orangepi.dtsi so-that it case use on respective orangepi h6 board dts files. Cc: zhaoyifan <zhao_steven@263.net> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-07-31board: sun50i: h6: Add OrangePi One Plus initial supportJagan Teki
OrangePi One Plus is Allwinner H6 based open-source SBC, which support: - Allwinner H6 Quad-core 64-bit ARM Cortex-A53 - GPU Mali-T720 - 1GB LPDDR3 RAM - AXP805 PMIC - 1Gbps GMAC via RTL8211 - USB 2.0 Host, OTG - HDMI port - 5V/2A DC power supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
