path: root/arch/arm/dts/sun50i-h5.dtsi
2018-07-16sunxi: DT: update device tree files for Allwinner H3 and H5 SoCsAndre Przywara
Update the device tree files from the Linux tree as of v4.18-rc3, exactly Linux commit: commit 55c5ba5e49a0a124ed416880e8227b493474495e Author: Chen-Yu Tsai <wens@csie.org> Date: Tue Apr 24 19:34:22 2018 +0800 arm64: dts: allwinner: h5: Add cpu0 label for first cpu Since the H3 and H5 are very similar (aside from the actual ARM cores), they share most the SoC .dtsi and thus have to be updated together. One tiny change is the removal of the "arm/" prefix from the include path in the sun50i-h5.dtsi, which is needed because we don't share the same sophisticated DT directory layout of Linux. Also we need to fix up the board .dts files already, since the .dtsi removes some pins, so the .dts can't reference them anymore. This is to maintain bisectability. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2017-11-21arm64: sun50i-h5.dtsi : update to kernel 4.14Antony Antony
last Kernel commit of sun50i-h5.dtsi d86e63e1f0b7 Signed-off-by: Antony Antony <antony@phenome.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-06-01arm64: dts: sun50i: Add sun50i-h5.dtsiJagan Teki
The Allwinner H5 SoC is pin-compatible to the H3 SoC, but uses Cortex-A53 cores instead. So move the shared cpu based and peripherals nodes into sun50i-h5.dtsi so, that it can shared among the sun50i-h5 board dts files. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
