Update the H5 DT files from the Linux 5.12 release.
The changes don't affect U-Boot at all, but fix Gigabit Ethernet when
this DT is passed on to the Linux kernel. It also introduces DVFS.
This also updates the shared sunxi-h3-h5.dtsi, but that only adds nodes
that are of no concern to U-Boot.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Sync the device tree files and device tree header files from upstream
Linux kernel, as of 2020-01-08. The commit synced to in the sunxi repo
98d25b0b266d Merge branch 'sunxi/dt-for-5.6' into sunxi/for-next
which is also part of next-20200108.
Changes brought in include:
- cleanup of pinmux node names
- addition of Security ID, MBUS, CSI, crypto engine, video codec,
pmu, and thermal sensor device nodes for both SoCs
- addition of deinterlacing engine device node on H3
- cleanup of RTC device node and addition of its clocks
- various board cleanups and improvements
- removal of pinmux node for GPIO lines
- cpufreq / DVFS
- HDMI output
- UART-based Bluetooth
- audio codec
- USB ports
- new boards
Most of the changes don't concern U-boot.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Update the .dts file for the various boards with an Allwinner H5 SoC.
This is as of v4.18-rc3, exactly Linux commit:
commit af5d05bdc99c211729cba0a3d5417bccfa308caf
Author: Neil Armstrong <narmstrong@baylibre.com>
Date: Tue Apr 24 13:47:14 2018 +0200
arm64: dts: allwinner: Add dts file for Libre Computer Board ALL-H3-CC H5 ver.
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
Update the device tree files from the Linux tree as of v4.18-rc3,
commit 55c5ba5e49a0a124ed416880e8227b493474495e
Author: Chen-Yu Tsai <wens@csie.org>
Date: Tue Apr 24 19:34:22 2018 +0800
arm64: dts: allwinner: h5: Add cpu0 label for first cpu
Since the H3 and H5 are very similar (aside from the actual ARM cores),
they share most the SoC .dtsi and thus have to be updated together.
One tiny change is the removal of the "arm/" prefix from the include
path in the sun50i-h5.dtsi, which is needed because we don't share the
same sophisticated DT directory layout of Linux.
Also we need to fix up the board .dts files already, since the .dtsi
removes some pins, so the .dts can't reference them anymore. This is to
maintain bisectability.
Add initial DT for NanoPi NEO Plus2 by FriendlyARM
- Allwinner quad core H5 Cortex A53 with an ARM Mali-450MP GPU
- 1 GB DDR3 RAM
- 8GB eMMC flash (Samsung KLM8G1WEPD-B031)
- micro SD card slot
- Gigabit Ethernet (external RTL8211E-VB-CG chip)
- 802.11 b/g/n WiFi, Bluetooth 4.0 (Ampak AP6212A module)
- 2x USB 2.0 host ports
Signed-off-by: Antony Antony <antony@phenome.org>
Reviewed-by: Jagan Teki <jagan@openedev.com>
