path: root/arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts
2018-07-16sunxi: DT: H5: update board .dts files from LinuxAndre Przywara
Update the .dts file for the various boards with an Allwinner H5 SoC. This is as of v4.18-rc3, exactly Linux commit: commit af5d05bdc99c211729cba0a3d5417bccfa308caf Author: Neil Armstrong <narmstrong@baylibre.com> Date: Tue Apr 24 13:47:14 2018 +0200 arm64: dts: allwinner: Add dts file for Libre Computer Board ALL-H3-CC H5 ver. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2018-07-16sunxi: DT: update device tree files for Allwinner H3 and H5 SoCsAndre Przywara
Update the device tree files from the Linux tree as of v4.18-rc3, exactly Linux commit: commit 55c5ba5e49a0a124ed416880e8227b493474495e Author: Chen-Yu Tsai <wens@csie.org> Date: Tue Apr 24 19:34:22 2018 +0800 arm64: dts: allwinner: h5: Add cpu0 label for first cpu Since the H3 and H5 are very similar (aside from the actual ARM cores), they share most the SoC .dtsi and thus have to be updated together. One tiny change is the removal of the "arm/" prefix from the include path in the sun50i-h5.dtsi, which is needed because we don't share the same sophisticated DT directory layout of Linux. Also we need to fix up the board .dts files already, since the .dtsi removes some pins, so the .dts can't reference them anymore. This is to maintain bisectability. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2017-11-21sun50i: h5: Add NanoPi Neo Plus2 DT initial supportAntony Antony
Add initial DT for NanoPi NEO Plus2 by FriendlyARM - Allwinner quad core H5 Cortex A53 with an ARM Mali-450MP GPU - 1 GB DDR3 RAM - 8GB eMMC flash (Samsung KLM8G1WEPD-B031) - micro SD card slot - Gigabit Ethernet (external RTL8211E-VB-CG chip) - 802.11 b/g/n WiFi, Bluetooth 4.0 (Ampak AP6212A module) - 2x USB 2.0 host ports Signed-off-by: Antony Antony <antony@phenome.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
