path: root/arch/arm/dts/sun50i-a64.dtsi
2017-08-11sun50i: a64: Sync Linux [oe]hci0 nodesJagan Teki
Synced ohci0 and ehci0 nodes from Linux for sun50i-a64.dtsi Here is the Linux last merge tag details: Merge: 0e91f43d e5770b7 Author: Stephen Rothwell <sfr@canb.auug.org.au> Date: Fri Jun 9 14:59:55 2017 +1000 Merge remote-tracking branch 'staging/staging-next' Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-01sunxi: A64/Pine64: update device tree from LinuxAndre Przywara
The Linux device tree for the Allwinner A64 SoC has changed a lot since the U-Boot version was merged. Let's replace the current DT with a exact copy of the Linux one as of: commit c6778ff813d2ca3e3c8733c87dc8b6831a64578b Merge: 0ff4c01 3c0e3abd Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Tue May 9 10:07:33 2017 -0700 This is the DT used in Linux 4.12-rc1. Since U-Boot has an Ethernet driver (while Linux does not yet), we provide the required DT nodes for it in an ...-u-boot.dtsi file, to both mark them as U-Boot specific and to allow easier upgrading once Linux gets the driver and its own binding later. Compared to the existing Ethernet DT nodes we just slightly tweak the clock and reset nodes in there to match the new bindings used by Linux for those. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-30sunxi: A64: enable USB supportAmit Singh Tomar
Mostly by adding MACH_SUN50I to some existing #ifdefs enable support for the the HCI0 USB host controller on the A64. Fix up some minor 64-bit hiccups on the way. Add the bare minimum DT bits to the A64 .dtsi and enable the controllers and the PHY on the Pine64. This is limited to the first USB controller at the moment, which is connected to the lower USB socket on the Pine64 board. [Andre: remove unneeded defines, enable OHCI, add commit message] Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-07-15net: Add EMAC driver for H3/A83T/A64 SoCs.Amit Singh Tomar
This patch add EMAC driver support for H3/A83T/A64 SoCs. Tested on Pine64(A64-External PHY) and Orangepipc(H3-Internal PHY). BIG Thanks to Andre for providing some of the DT code. Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-05-25arm64: Pine64: update FDT filesAndre Przywara
The originally committed .dts files for the Pine64 were from an early proof-of-concept version and should have never been committed upstream. Replace them with much more mature versions, which also use a different naming scheme. Please note that at this point there is at least one binding which has not been agreed upon, so this is subject to change. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
