Import updated devicetree files from the Linux v5.12 release.
Besides some node and audio port renames this changes the PHY modes to
either rgmii-id or rgmii-txid. From the board files the Pinephone sees
a lot of updates.
This also adds the long missing USB PHY property for controller 0, which
allows the U-Boot PHY driver to eventually use port 0 in host mode
(pending another U-Boot patch).
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Jernej Skrabec <jernej.skrabec@siol.net>
Import updated device trees from Linux tag v5.9. This picks up new
hardware (PinePhone, PineTab); and it drops the U-Boot specific DTSI
files for the Pinebook and the Teres-I, since the ANX6345 bridge is
now supported upstream.
A couple of headers needed updates for recently-added hardware support.
Acked-by: Maxime Ripard <mripard@kernel.org>
Signed-off-by: Samuel Holland <samuel@sholland.org>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Olimex A64-Teres-I board is a mainboard (the only one so far)
for Olimex Teres-I DIY laptop kit.
Key features:
- Allwinner A64 Cortex-A53
- Mali-400MP2 GPU
- AXP803 PMIC
- 2GB DDR3 RAM
- MicroSD Slot
- 16GB eMMC Flash
- eDP LCD display
- HDMI
- USB Host
- Battery management
- 5V DC power supply
- Certified Open Source Hardware (OSHW)
Works:
- i2C
- MMC/SD
- PWM backlight
Known broken:
- Internal keyboard (seems to be because the keyboard firmware loads a
bootloader first, and then disconnects bootloader and connect real
keyboard). External ones connected to the USB port work fine.
This patch enables support for the A64-Teres-I board to u-boot,
including enabling screen backlight (lacking from Linux device-tree).
Linux commit details about the sun50i-a64-teres-i.dts sync:
"arm64: dts: allwinner: a64: Rename uart0_pins_a label to uart0_pb_pins"
(sha1: d91ebb95b96c8840932dc3a10c9f243712555467)
Cosmetic warnings regarding whitespace and placement of SPDX notice for
dts file was ignored.
config and .dtsi file are adapted from pinebook files.
Tested-by: Jonas Smedegaard <dr@jones.dk>
Signed-off-by: Jonas Smedegaard <dr@jones.dk>
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
[jagan: move board entry in MAINTAINERS file at proper position]
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
