Import updated devicetree files from the Linux v5.12 release.
Besides some node and audio port renames this changes the PHY modes to
either rgmii-id or rgmii-txid. From the board files the Pinephone sees
a lot of updates.
This also adds the long missing USB PHY property for controller 0, which
allows the U-Boot PHY driver to eventually use port 0 in host mode
(pending another U-Boot patch).
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Jernej Skrabec <jernej.skrabec@siol.net>
Import updated device trees from Linux tag v5.9. This picks up new
hardware (PinePhone, PineTab); and it drops the U-Boot specific DTSI
files for the Pinebook and the Teres-I, since the ANX6345 bridge is
now supported upstream.
A couple of headers needed updates for recently-added hardware support.
Acked-by: Maxime Ripard <mripard@kernel.org>
Signed-off-by: Samuel Holland <samuel@sholland.org>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Update the .dts/.dtsi file from the Linux sunxi/dt64-for-4.20 tree:
commit 679294497be31596e1c9c61507746d72b6b05f26
Author: Rodrigo Exterckötter Tjäder <rodrigo@tjader.xyz>
Date: Wed Sep 26 19:48:24 2018 +0000
arm64: dts: allwinner: a64: a64-olinuxino: set the PHY TX delay
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Update the .dts files for the various boards with an Allwinner A64 SoC.
This is as of v4.18-rc3, exactly Linux commit:
commit 818668055c9d588c9a9d151e3b258ed1adacba0b
Author: Jagan Teki <jagan@amarulasolutions.com>
Date: Mon Apr 23 12:02:39 2018 +0530
arm64: dts: allwinner: a64: bananapi-m64: add usb otg
It updates the existing DT files, adds the newly added axp803.dtsi and
removes our temporary kludge file to get Ethernet support in U-Boot.
I left the amarula-relic alone, as this DT has not reached mainline yet.
The changes are not critical anyway, and the next sync will fix this.
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com>
The Linux device tree for the Allwinner A64 SoC has changed a lot since
the U-Boot version was merged.
Let's replace the current DT with a exact copy of the Linux one as of:
commit c6778ff813d2ca3e3c8733c87dc8b6831a64578b
Merge: 0ff4c01 3c0e3abd
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Tue May 9 10:07:33 2017 -0700
This is the DT used in Linux 4.12-rc1.
Since U-Boot has an Ethernet driver (while Linux does not yet), we
provide the required DT nodes for it in an ...-u-boot.dtsi file, to both
mark them as U-Boot specific and to allow easier upgrading once Linux gets
the driver and its own binding later.
Compared to the existing Ethernet DT nodes we just slightly tweak the clock
and reset nodes in there to match the new bindings used by Linux for those.
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The originally committed .dts files for the Pine64 were from an early
proof-of-concept version and should have never been committed upstream.
Replace them with much more mature versions, which also use a different
naming scheme.
Please note that at this point there is at least one binding which has
not been agreed upon, so this is subject to change.
Acked-by: Hans de Goede <hdegoede@redhat.com>
