path: root/arch/arm/dts/sun50i-a64-pine64-lts.dts
2018-11-13sunxi: A64: Add Pine64-LTS boardAndre Przywara
The Pine64 LTS is an updated version of the Pine64, copying the technical updates from the SoPine platform: LPDDR3 DRAM, eMMC socket and soldered SPI flash chip, even the broken SD card detect pin has been copied. Consequently this leads to the .dts (copied from the kernel) just including the SoPine baseboard .dts, and the defconfig being almost identical. Nevertheless the boards deserves a separate config. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
