path: root/arch/arm/dts/sun4i-a10-inet9f-rev03.dts
2018-09-28ARM: dts: sun4i: Update A10 dts(i) files from Linux-v4.18-rc3Jagan Teki
Update all A10 devicetree dtsi and dtsi files from Linux-v4.18-rc3 with below commit: commit 590b0c0cfc6162aeebbf43eaafb9753b56df1532 Author: Pascal Roeleven <dev@pascalroeleven.nl> Date: Fri Apr 20 12:21:12 2018 +0200 ARM: dts: sun4i: Fix incorrect clocks for displays Note: Update pinctrl-0 for sun4i-a10-inet-3f.dts, sun4i-a10-inet-3w.dts like other dts file since there dts file are U-Boot specific. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-03-23sunxi: Sync dts files with the upstream kernelHans de Goede
Sync dts files with the upstream kernel including changes queued for 4.6: https://git.kernel.org/cgit/linux/kernel/git/mripard/linux.git/commit/?h=sunxi/dt-for-4.6 Note this adds a number of new unused board dts files. I've asked the authors of the kernel commits adding these to submit a matching defconfig to u-boot. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-09-10sun4i: Add defconfig and dts for inet9f-rev03 based tabletsHans de Goede
The inet9f-rev03 pcb is specially designed for gaming tablets, such as the qware tb-g100 tablet. These 7" tablets feature a dpad, firebuttons and 2 joysticks on the sides of the screen. Besides this they have the usual connectors: power-barrel, mini usb, mini hdmi, headphone and micro-sd slot. The dts is identical to the dts submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
