path: root/arch/arm/dts/sun4i-a10-inet-3w.dts
2018-09-28ARM: dts: sun4i: Update A10 dts(i) files from Linux-v4.18-rc3Jagan Teki
Update all A10 devicetree dtsi and dtsi files from Linux-v4.18-rc3 with below commit: commit 590b0c0cfc6162aeebbf43eaafb9753b56df1532 Author: Pascal Roeleven <dev@pascalroeleven.nl> Date: Fri Apr 20 12:21:12 2018 +0200 ARM: dts: sun4i: Fix incorrect clocks for displays Note: Update pinctrl-0 for sun4i-a10-inet-3f.dts, sun4i-a10-inet-3w.dts like other dts file since there dts file are U-Boot specific. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-05-07SPDX: Convert all of our multiple license tags to Linux Kernel styleTom Rini
When U-Boot started using SPDX tags we were among the early adopters and there weren't a lot of other examples to borrow from. So we picked the area of the file that usually had a full license text and replaced it with an appropriate SPDX-License-Identifier: entry. Since then, the Linux Kernel has adopted SPDX tags and they place it as the very first line in a file (except where shebangs are used, then it's second line) and with slightly different comment styles than us. In part due to community overlap, in part due to better tag visibility and in part for other minor reasons, switch over to that style. This commit changes all instances where we have multiple licenses (in these cases, dual license) declared in the SPDX-License-Identifier tag. In this case we change from listing "LICENSE-A LICENSE-B" or "LICENSE-A or LICENSE-B" or "(LICENSE-A OR LICENSE-B)" to "LICENSE-A OR LICENSE-B" as per the Linux Kernel style document. Note that parenthesis are allowed so when they were used before we continue to use them. Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-05-04sunxi: dts: Add minimal dts files for board which lack a dts sofarHans de Goede
u-boot has support for a number of boards for which a dts file still needs to be written, add minimal dts files for these boards so that we can switch them over to driver-model / fdt. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org>
