path: root/arch/arm/dts/stv0991.dts
2015-07-03spi: cadence_qspi: add device tree binding docVikas Manocha
This patch adds the device tree binding doc for the cadence qspi controller & also removes the not needed properties from the stv0991 device tree. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-07-03spi: cadence_qspi: get sram size from device treeVikas Manocha
sram size could be different on different socs, e.g. on stv0991 it is 256 while on altera platform it is 128. It is better to receive it from device tree. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Tested-by: Stefan Roese <sr@denx.de> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-07-03stv0991: configure device tree for cadence qspi & flashVikas Manocha
This patch add the device tree entry for qspi controller & spi flash memory. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-05-10stv0991: fdt: add stv0991 device treeVikas Manocha
This patch adds device tree for the ST Micro stv0991 board & enables device tree control. Progressively device tree support for the drivers being used will also be added. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
