path: root/arch/arm/dts/stm32h743-pinctrl.dtsi
2019-04-23ARM: dts: stm32: Sync DT with v4.20 kernel for stm32h7Patrice Chotard
Synchronize stm32h7 device tree with kernel v4.20. U-boot DT files and pinctrl bindings are updated, useless nodes are removed and gpio compatible added. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-04-23ARM: dts: Migrate U-boot nodes to U-boot DT files for stm32h7Patrice Chotard
In order to prepare and ease future DT synchronization with kernel DT, migrate all U-boot specific nodes/properties/addons to U-boot DT files. As sdmmc is not yet supported on kernel side, sdmmc nodes are located in eval-u-boot and disco-u-boot DT files. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-10-08ARM: DTS: stm32: add SDMMC support fo stm32h743-evalPatrice Chotard
Add pinctrl and sdmmc nodes to add MMC support for STM32H743 evaluation board. Evaluation board needs a second pinctrl node "pinctrl_sdmmc1_level_shifter" to drive a level shifter on MMC bus. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-10-08ARM: DTS: stm32: add SDMMC support for stm32h743 discoPatrice Chotard
Add pinctrl and sdmmc nodes to add MMC support for STM32H743 discovery board. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-09-22ARM: DTS: stm32: adapt stm32h7 dts files for U-bootPatrice Chotard
This patch adapts stm32h743 disco and eval dts files to match with U-boot requirements or add features wich are not yet upstreamed on kernel side : _ Add RCC clock driver node and update all clocks phandle accordingly. By default, on kernel side, all clocks was temporarly configured as a phandle to timer_clk waiting for a RCC clock driver to be available. On U-boot side, we now have a dedicated RCC clock driver, we can configured all clocks as phandle to this driver. All this binding update will be available soon in a kernel tag, as all the bindings have been acked by Rob Herring [1]. [1] http://lkml.iu.edu/hypermail/linux/kernel/1704.0/00935.html _ Align STM32H7 serial compatible string with the one which will be available in next kernel tag. The bindings has been acked by Rob Herring [2]. This compatible string will be usefull to add stm32h7 specific feature for this serial driver. [2] https://lkml.org/lkml/2017/7/17/739 _ Add gpio compatible and aliases for stm32h743 _ Add FMC sdram node with associated new bindings value to manage second bank (ie bank 1). _ Add missing HSI and CSI oscillators nodes needed by STM32H7 RCC clock driver. Clock sources could be: _ HSE (High Speed External) _ HSI (High Speed Internal) _ CSI (Low Power Internal) These clocks can be used as clocksource in some configuration. By default, HSE is selected as clock source. _ Set HSE to 25Mhz for stm32h743i-disco and eval board By default, the external oscillator frequency is defined at 25 Mhz in SoC stm32h743.dtsi file. It has been set at 125 Mhz in kernel DT temporarly waiting for RCC clock driver becomes available. As in U-boot we got a RCC clock driver, the real value of HSE clock can be used. _ Add "u-boot,dm-pre-reloc" for rcc, fmc, fixed-clock, pinctrl, pwrcfg and gpio nodes. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-22ARM: DTS: stm32: add stm32h743i-disco filesPatrice Chotard
All these files are imported from linux kernel v4.13 Add device tree support for STM32H743 SoC and discovery board. This board offers : _ STM32H743XIH6 microcontroller with 2 Mbytes of Flash memory and 1 Mbyte of RAM in TFBGA240+25 package _ 5.7” 640x480 TFT color LCD with touch screen _ Ethernet compliant with IEEE-802.3-2002 _ USB OTG HS _ I2 C compatible serial interface _ ST-MEMS digital microphones _ 8-Gbyte (or more) SDIO3.0 interface microSD™ card _ 8Mx32bit SDRAM _ 1-Gbit Twin Quad-SPI NOR Flash _ Reset, wakeup, or key buttons _ Joystick with 4-direction control and selector _ Board connectors : 1 USB with Micro-AB Ethernet RJ45 Stereo headset jack including analog microphone input microSD™ card RCA connector JTAG/SWD and ETM trace _ Expansion connectors: Arduino Uno compatible Connectors 2 x PIO connectors (PMOD and PMOD+) _ On-board ST-LINK/V2-1 debugger/programmer with USB re-enumeration capability: mass storage, virtual COM port and debug port Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
