path: root/arch/arm/dts/socfpga_stratix10.dtsi
2019-05-06arm: dts: Stratix10: Add SDRAM nodeLey Foon Tan
Add SDRAM device tree node. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-04-17arm: dts: Stratix10: Add QSPI nodeLey Foon Tan
Merge qspi dts node from Linux. Commit 0cb140d07fc75fb (arm64: dts: stratix10: Add QSPI support for Stratix10) Add -u-boot.dtsi files for non Linux dts properties and update properties for Uboot. - add u-boot,dm-pre-reloc - add alias for spi0 - change compatible for flash - support quad read and quad write - change maximum frequency to 100MHz Tested on Stratix 10 SoC devkit. SOCFPGA_STRATIX10 # sf probe 0:0 SF: Detected mt25qu02g with page size 256 Bytes, erase size 64 KiB, total 256 MiB Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-03-16ARM: dts: socfpga: Add missing altr,sysmgr-syscon for EMACLey Foon Tan
Syscon register is required in dts to select correct PHY interface. Fix error below: Net: Failed to get syscon: -2 Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2018-05-18arm: dts: socfpga: stratix10: update dtsi and dtsLey Foon Tan
Update dtsi and dts files for resets, phy node and other properties. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2018-04-17ARM: dts: stratix10: Add base dtsi and devkit dtsDinh Nguyen
From the Linux v4.16-rc4, add the base dtsi and devkit dts files for the Stratix10 SoCFPGA platform. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
