path: root/arch/arm/dts/socfpga_cyclone5_dbm_soc1.dts
2023-04-12dm: dts: Convert driver model tags to use new schemaSimon Glass
Now that Linux has accepted these tags, move the device tree files in U-Boot over to use them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
2019-04-17arm: socfpga: gen5: add reset & sdr node to SPL devicetreesSimon Goldschmidt
The SPL for socfpga gen5 currently takes all peripherals out of reset unconditionally. To implement proper reset handling for peripherals, the reset node has to be provided with the SPL dts. In preparation to move the DDR driver to DM, the sdr node is required in SPL, too. This patch adds "u-boot,dm-pre-reloc" to U-Boot specific dtsi addon files so that the reset manager and SDR driver correctly probe in SPL. It centralizes these settings into a common file since in contrast to boot-type specific nodes, "soc", "rst" and "sdr" are always needed. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-11-29dts: arm: socfpga: merge gen5 devicetrees from linuxSimon Goldschmidt
Add -u-boot.dtsi files to keep the current U-Boot behaviour: - add u-boot,dm-pre-reloc where required - disable watchdog - set uart clock frequency - add gpio bank-name properties where appropriate: - make qspi work (add alias for spi0, fix compatible for flash) - enable usb (status okay, add alias for udc0) Adapt board dts files that are not in Linux to keep their old behaviour. Change licenses to SPDX. (Patman warnings/errors are in 1:1 copied files from Linux) Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-08-13arm: socfpga: fix device trees to work with DM serialSimon Goldschmidt
Device trees need to have the serial console device available before relocation and require a stdout-path in chosen at least for SPL to have a console. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-02-26ARM: socfpga: Add new CycloneV SoC Devboards DBM-SoC1 boardMarek Vasut
Add support for a new boards from devboards.de , the DBM-SoC1 . This board has one ethernet port, one USB OTG port and USB UART. Signed-off-by: Marek Vasut <marex@denx.de>
