path: root/arch/arm/dts/socfpga_arria5_socdk-u-boot.dtsi
2019-04-17arm: socfpga: gen5: add reset & sdr node to SPL devicetreesSimon Goldschmidt
The SPL for socfpga gen5 currently takes all peripherals out of reset unconditionally. To implement proper reset handling for peripherals, the reset node has to be provided with the SPL dts. In preparation to move the DDR driver to DM, the sdr node is required in SPL, too. This patch adds "u-boot,dm-pre-reloc" to U-Boot specific dtsi addon files so that the reset manager and SDR driver correctly probe in SPL. It centralizes these settings into a common file since in contrast to boot-type specific nodes, "soc", "rst" and "sdr" are always needed. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-04-12dts: switch spi-flash to jedec, spi-nor compatibleNeil Armstrong
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot dts files. This compatible has been added in sf_probe, let use it. This patch switches to jedec,spi-nor when spi-flash is used in the DTS and DTSI files, and removed spi-flash when jedec,spi-nor is already present. The x86 dts are switched in a separate commit since it depends on a change in fdtdec. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com> Reviewed-by: Rick Chen <rick@andestech.com> Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-11-29dts: arm: socfpga: merge gen5 devicetrees from linuxSimon Goldschmidt
Add -u-boot.dtsi files to keep the current U-Boot behaviour: - add u-boot,dm-pre-reloc where required - disable watchdog - set uart clock frequency - add gpio bank-name properties where appropriate: - make qspi work (add alias for spi0, fix compatible for flash) - enable usb (status okay, add alias for udc0) Adapt board dts files that are not in Linux to keep their old behaviour. Change licenses to SPDX. (Patman warnings/errors are in 1:1 copied files from Linux) Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
