path: root/arch/arm/dts/sama5d33ek.dts
2017-04-13ARM: at91: dt: add dts files for sama5d3xek boardWenyou Yang
Add the device tree files for sama5d3xek board. The dts files are copied from Linux-4.9, do the changes as below. - add reg property for the pinctrl node. - move the gpio nodes (pioA, pioB, pioC ...) as the pinctrl's slibling nodes. - add the "u-boot,dm-pre-reloc" property to determine which nodes which are needed by SPL and by the board_init_f stage. - fix the compile warning. - add spi0 node aliases. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
