path: root/arch/arm/dts/sama5d3.dtsi
2018-09-28ARM: dts: at91: sama5d3_xplained: add onewire connector for LCD eepromEugen Hristev
Add onewire node in device tree for TM series LCDs Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-10at91: fix devicetree warningsEugen Hristev
This commit fixes various devicetree warnings in the at91 devicetrees like: arch/arm/dts/sama5d36ek_cmp.dtb: Warning (avoid_unnecessary_addr_size): /gpio_keys: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property These warnings make buildman report failed builds for most of at91 boards. Thus, fixing it. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2017-09-14ARM: dts: at91: sama5: Add the sfr nodeWenyou Yang
For sama5d2, add the sfr node with syscon support. In order to access the SFR_UTMICKTRIM register for the utmi clock driver, add the phandle property for the utmi node to point to the sfr node. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-04-13ARM: at91: dt: add dts files for sama5d3xek boardWenyou Yang
Add the device tree files for sama5d3xek board. The dts files are copied from Linux-4.9, do the changes as below. - add reg property for the pinctrl node. - move the gpio nodes (pioA, pioB, pioC ...) as the pinctrl's slibling nodes. - add the "u-boot,dm-pre-reloc" property to determine which nodes which are needed by SPL and by the board_init_f stage. - fix the compile warning. - add spi0 node aliases. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
