path: root/arch/arm/dts/rv1108.dtsi
2018-11-30ARM: dts: rockchip: Add rv1108 USB OTG pinctrlOtavio Salvador
This adds the definitions need to use the USB OTG in rv1108 board. This has been tested using USB Mass Storage to export and program a eMMC device. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-11-30ARM: dts: rockchip: Add rv1108 eMMC pinctrlOtavio Salvador
This adds the pinctrl handles to enable the use of eMMC on custom boards (as minievk) and makes it easier for later addition. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-10-01rockchip: dts: rv1108: Add SARADC node at dtsi levelDavid Wu
Signed-off-by: David Wu <david.wu@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-09-18ARM: dts: rockchip: add USB nodes for evb-rv1108William Wu
This patch adds USB OTG/EHCI/OHCI nodes for evb-rv1108 USB ports. Signed-off-by: William Wu <william.wu@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-07rockchip: Add basic support for evb-rv1108 boardAndy Yan
Add basic support for rv1108 evb, whith this patch we can boot into u-boot console. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
