path: root/arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi
2019-11-17ram: rk3399: migrate to use common codeYouMin Chen
For there are some structures and functions are common for all rockchip SoCs, migrate to use the common code so that we can clean up reduandent codes. Signed-off-by: YouMin Chen <cym@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-21rockchip: dts: rk3399: Add LPDDR4-100 timingsJagan Teki
Add sdram timings for LPDDR4-100 via rk3399-sdram-lpddr4-100.dtsi file. all timings are dumped from rkbin/bin/rk33/rk3399_ddr_800MHz_v1.20.bin Associated LPDDR4 board -u-boot.dtsi can include this to make these timings available during SPL or TPL stages. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: YouMin Chen <cym@rock-chips.com> Reviewed-by: Kever Yang <Kever.yang@rock-chips.com>
