path: root/arch/arm/dts/rk3399-sdram-ddr3-1866.dtsi
2017-06-07rockchip: dts: rk3399-puma: Add DDR3-1866 timingsPhilipp Tomsich
With the validation done for DDR3-1866 (i.e. 933 MHz bus clock), we can now add the timings (rk3399-sdram-ddr3-1866.dtsi) for boards built with the DDR3-1866 option. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
