path: root/arch/arm/dts/rk3399-rock-pi-4a.dts
2021-08-12arm: dts: sync the Rockhip 3399 SoCs from LinuxPeter Robinson
Sync the rk3399 DTs and associated bits from 5.14-rc1. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> (Remove the conflict content for vmarc-som) Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2020-07-22arm64: dts: rockchip: Add ROCKPi 4A/4B supportJagan Teki
Rock PI 4 has 3 variants of hardware platforms called RockPI 4A, 4B, and 4C. - Rock PI 4A has no Wif/BT. - Rock PI 4B has AP6256 Wifi/BT, PoE. - Rock PI 4C has AP6256 Wifi/BT, PoE, miniDP, USB Host enable GPIO pin change compared to 4B, 4C So move common nodes, properties into dtsi file and include on respective variant dts files. Use 4B dts into default rock-pi-4 defconfig until we find any solution for dynamic detection of these variants. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
