Sync the rk3399 DTs and associated bits from 5.14-rc1.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
(Remove the conflict content for vmarc-som)
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Sync rk3399 dts(i) files from v5.7-rc1 linux-next.
Reason:
To get updated PCIe nodes and properties on respective
dts(i) files.
Summary:
- sync won't include new board dts(i)
- sync will add required files used on respective dts(i)
- rk3399-puma-u-boot.dtsi spiflash label changed to norflash
- move puma.dtsi bios_enable into rk3399-puma-u-boot.dtsi
- move legacy max-frequency of sdhci into rk3399-u-boot.dtsi
- update cross-ec-[keyboard|sbs].dtsi path as per U-Boot
- keep roc-rk3399-pc dc_12v changes to -u-boot.dtsi
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Sync the ROC-RK3399-PC device tree changes from Linux
with below commit details:
commit <c36308abe4110e4db362d5e2ae3797834a7b1192> ("arm64: dts:
rockchip: Enable MTD Flash on rk3399-roc-pc")
