Now that Linux has accepted these tags, move the device tree files in
U-Boot over to use them.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
SPI flash on this board is located on bus 1, default to using bus 1 for
SPI flash on both rk3399-roc-pc and -mezzanine, and stop aliasing it to
bus 0.
Signed-off-by: Hugh Cole-Baker <sigmaris@gmail.com>
Suggested-by: Simon Glass <sjg@chromium.org>
Fixes: c4cea2bb ("rockchip: Enable building a SPI ROM image on bob")
Reviewed-by: Kever Yang<kever.yang@rock-chips.com>
U-Boot TPL 2020.07-rc3-00090-gd4e919f927-dirty (Jun 01 2020 - 23:45:53)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB
Channel 1: LPDDR4, 50MHz
256B stride
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...
U-Boot SPL 2020.07-rc3-00087-ga21e9fd385 (Jun 02 2020 - 00:09:45 +0530)
Trying to boot from MMC1
NOTICE: BL31: v2.2(release):
NOTICE: BL31: Built : 15:05:37, May 12 2020
U-Boot 2020.07-rc3-00087-ga21e9fd385 (Jun 02 2020 - 00:09:45 +0530)
SoC: Rockchip rk3399
Reset cause: POR
Model: Firefly ROC-RK3399-PC Board
DRAM: 3.9 GiB
PMIC: RK808
MMC: mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from SPI Flash... SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Sync rk3399 dts(i) files from v5.7-rc1 linux-next.
Reason:
To get updated PCIe nodes and properties on respective
dts(i) files.
Summary:
- sync won't include new board dts(i)
- sync will add required files used on respective dts(i)
- rk3399-puma-u-boot.dtsi spiflash label changed to norflash
- move puma.dtsi bios_enable into rk3399-puma-u-boot.dtsi
- move legacy max-frequency of sdhci into rk3399-u-boot.dtsi
- update cross-ec-[keyboard|sbs].dtsi path as per U-Boot
- keep roc-rk3399-pc dc_12v changes to -u-boot.dtsi
roc-rk3399-pc has an FE1.1 USB 2.0 HUB which connects two USB ports
(HOST1 and HOST2). For end devices to work we need to enable USB hub
so that HOST detects there presence and enumerates them accordingly.
This requires explicit pinctrl within gpio enablement.
Signed-off-by: Suniel Mahesh <sunil@amarulasolutions.com>
Enable winbond SPI flash for ROC-PC-RK3399 board.
Add initial support for ROC-RK3399-PC board.
Specification
- Rockchip RK3399
- LPDDR4 4GiB
- eMMC slot
- SD card slot
- RTL8211E 1Gbps
- HDMI Out, DP, MIPI DSI/CSI, EDP
- PCIe M.2
- USB 2.0, USB-3.0
- USB C Type
Commit details of rk3399-roc-pc.dts sync from Linux v5.2:
"arm64: dts: rockchip: add support for ROC-RK3399-PC board"
(sha1: 8bb878cf20ae10809c36db96993bfce7026d062b)
Signed-off-by: Levin Du <djw@t-chip.com.cn>
