Sync the rk3399 DTs and associated bits from 5.14-rc1.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
(Remove the conflict content for vmarc-som)
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Remove the recommended MAC address from the network card.
NanoPi R4S has a EEPROM attached to the 2nd I2C bus (U92), which stores the MAC address.
Signed-off-by: Xiaobo Tian <peterwillcn@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
The host-index-min property is invalid,
so it inherits from the sdmmc definition in dtsi.
Correct the LEDS label name and remove the board type prefix,
which is actually unnecessary here, removes the redefined system status LED pin.
NanoPi R4s is SBC base on Rockchip RK3399 hexa-core processor with
dual-Core Cortex-A72 and Mali-T864 GPU with 4GiB(LPDDR4) of RAM, SD card support,
including 2 gigabit ethernet(RTL8211E 1Gbps - RTL8111H 1Gbps) and 2 USB 3.0 port.
port.It also has two GPIO headers which allows further peripherals to be used.
The devicetree file is taken of the rk3399 nanopi4 Linux kernel [1].
[1] https://github.com/torvalds/linux/commit/e7a095908227fb3ccc86d001d9e13c9ae2bef8e6
Signed-off-by: xiaobo <peterwillcn@gmail.com>
