path: root/arch/arm/dts/rk3399-leez-p710.dts
2020-05-01arm64: dts: rk3399: Sync v5.7-rc1 from LinuxJagan Teki
Sync rk3399 dts(i) files from v5.7-rc1 linux-next. Reason: To get updated PCIe nodes and properties on respective dts(i) files. Summary: - sync won't include new board dts(i) - sync will add required files used on respective dts(i) - rk3399-puma-u-boot.dtsi spiflash label changed to norflash - move puma.dtsi bios_enable into rk3399-puma-u-boot.dtsi - move legacy max-frequency of sdhci into rk3399-u-boot.dtsi - update cross-ec-[keyboard|sbs].dtsi path as per U-Boot - keep roc-rk3399-pc dc_12v changes to -u-boot.dtsi Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-10rockchip: rk3399: Add Leez P710 supportAndy Yan
Specification - Rockchip RK3399 - LPDDR4 - TF sd scard slot - eMMC - M.2 B-Key for 4G LTE - AP6256 for WiFi + BT - Gigabit ethernet - HDMI out - 40 pin header - USB 2.0 x 2 - USB 3.0 x 1 - USB 3.0 Type-C x 1 - TYPE-C Power supply Commit details of rk3399-leez-p710.dts sync from linus tree for Linux 5.4-rc1: "arm64: dts: rockchip: Add dts for Leez RK3399 P710 SBC" (sha1: fc702ed49a8668a17343811ee28214d845bfc5e6) Signed-off-by: Andy Yan <andyshrk@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
