path: root/arch/arm/dts/rk3399-ficus-u-boot.dtsi
2019-05-08arm64: rockchip: dts: rk3399: Add board -u-boot.dtsi filesJagan Teki
Devicetree files in RK3399 platform is synced from Linux, like other platforms does. Apart from these u-boot in rk3399 would also require some u-boot specific node like dmc. dmc node has big chunk of DDR timing parameters which are specific to specific board, and maintained with rk3399-sdram*.dtsi. So, create board specific -u-boot.dtsi files and move these sdram dtsi files accordingly. This would help of maintain u-boot specific changes separately without touching Linux dts(i) files which indeed easy for syncing from Linux between releases. These board specific -u-boot.dtsi can be extendible to add more u-boot specific nodes or properties in future. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
