Sync the rk3328 DTs and associated bits from 5.14-rc1.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
This syncs rk3328 device tree files from the Linux kernel next-20200324.
The last commit to touch these files is:
b2411befed60 ("arm64: dts: add bus to rockchip amba nodenames")
Additional changes not yet in the Linux kernel include:
arm64: dts: rockchip: rk3328: drop #address-cells, #size-cells from grf node
arm64: dts: rockchip: rk3328: drop non-existent gmac2phy pinmux options
arm64: dts: rockchip: rk3328: Replace RK805 PMIC node name with "pmic"
Changes include:
- conversion of raw pin numbers to macros
- removal of deprecated RK_FUNC_* macros
- update of device tree binding headers
- new devices
- device tree cleanups
- gmac2phy disabled in -u-boot.dtsi as it is not supported in U-boot
This includes a re-ordering of the USB device nodes compared to upstream
Linux, moving the dwc2 OTG controller after the EHCI/OHCI nodes. This is
currently required as otherwise the dwc2 controller would not be able to
detect devices in some cases. This may be due to lack of USB PHY support
in U-boot.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
The "hnp-srp-disable" property for dwc2 is specific to U-boot, not part
of upstream Linux's device tree bindings.
Move it to rk3328-u-boot.dtsi to avoid losing it when syncing device
tree files.
Move all the nodes only shown in u-boot to -u-boot.dtsi to make
rk3328.dtsi clean.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Update dmc node for full feature driver.
[cherry picked from commit https://github.com/rockchip-linux/u-boot/commit/1e1495636574c78ea9d3af3e0aae95d5204612d6 with minor modifications]
Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
Fix warning below:
unnecessary #address-cells/#size-cells without "ranges" or child "reg"
property
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Add basic dts configuration for rk3328 gmac2io.
Signed-off-by: David Wu <david.wu@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Add aliases for mmc controller to get a fixed order with
emmc at index 0 and sdmmc at index 1.
Enable dwc2 controller and add fixed regulator for dwc2 controller to
control vbus.
Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com>
Since the 'clock-freq-min-max' is deprecated, we use max-frequency.
Add a dmc node for sdram driver.
Add dts binding header for rk3328, files origin from kernel.
Signed-off-by: William Zhang <william.zhang@rock-chips.com>
