path: root/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi
2020-01-30ram: rk3328: update lpddr3 settingYouMin Chen
update lpddr3 setting for fix init fail about "col error". Signed-off-by: YouMin Chen <cym@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-17ram: rk3328: use common sdram driverYouMin Chen
RK3328 has a similar controller and phy with PX30, so we can use the common driver for it and remove the duplicate codes. Signed-off-by: YouMin Chen <cym@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-05rockchip: dts: rk3328: update dmc node for driverKever Yang
Update dmc node for full feature driver. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> [cherry picked from commit https://github.com/rockchip-linux/u-boot/commit/1e1495636574c78ea9d3af3e0aae95d5204612d6 with minor modifications] Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
