Partial sync of rk3288.dtsi from Linux version 5.18
Changed:
only properties and functions that are not yet included
swap some clocks positions
fix some irq numbers
style and sort nodes
Signed-off-by: Johan Jonker <jbx6244@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
In order to better compare the Linux rk3288.dtsi version
with the u-boot version update the cpu and gpu nodes.
Changed:
use operating-points-v2
update thermal for all cpus
add labels to all cpus
change gpu compatible
change gpu interrupt names
with the u-boot version move thermal sub nodes to the dtsi
file and remove rk3288-thermal.dtsi
Changed:
replace underscore in nodename
remove comments about sensor and ID
use gpu phandle
add #cooling-cells to gpu node
lower critical temparature
remove linux,hwmon property
The boot_devices constants for rk3288 were changed to match the
binding, but the dtsi file was not synced.
Fix by renaming the rk3288 mmc node names.
Also correct the clock name for "ciu-drive".
with the u-boot version move the dma-controller nodes
to the DT root.
with the u-boot version sort the mipi,hdmi,lvds and dp nodes.
Changed:
Rename mipi_dsi label.
Rename dp nodename.
Bulk convert rk3288 DT gpios to their constant counterparts.
Partial Linux sync for the rk3288.dtsi file.
ARM: dts: rockchip: bulk convert gpios to their constant counterparts
https://lore.kernel.org/all/20190402121852.14442-1-heiko@sntech.de/
sed -i -f script.sed rk3288.dtsi
/rockchip,pins *=/bcheck
b # to end of script
:append-next-line
N
:check
/^[^;]*$/bappend-next-line
s/<RK_GPIO\([0-9]\) /<\1 /g
s/<\([^ ][^ ]* *\)0 /<\1RK_PA0 /g
s/<\([^ ][^ ]* *\)1 /<\1RK_PA1 /g
s/<\([^ ][^ ]* *\)2 /<\1RK_PA2 /g
s/<\([^ ][^ ]* *\)3 /<\1RK_PA3 /g
s/<\([^ ][^ ]* *\)4 /<\1RK_PA4 /g
s/<\([^ ][^ ]* *\)5 /<\1RK_PA5 /g
s/<\([^ ][^ ]* *\)6 /<\1RK_PA6 /g
s/<\([^ ][^ ]* *\)7 /<\1RK_PA7 /g
s/<\([^ ][^ ]* *\)8 /<\1RK_PB0 /g
s/<\([^ ][^ ]* *\)9 /<\1RK_PB1 /g
s/<\([^ ][^ ]* *\)10 /<\1RK_PB2 /g
s/<\([^ ][^ ]* *\)11 /<\1RK_PB3 /g
s/<\([^ ][^ ]* *\)12 /<\1RK_PB4 /g
s/<\([^ ][^ ]* *\)13 /<\1RK_PB5 /g
s/<\([^ ][^ ]* *\)14 /<\1RK_PB6 /g
s/<\([^ ][^ ]* *\)15 /<\1RK_PB7 /g
s/<\([^ ][^ ]* *\)16 /<\1RK_PC0 /g
s/<\([^ ][^ ]* *\)17 /<\1RK_PC1 /g
s/<\([^ ][^ ]* *\)18 /<\1RK_PC2 /g
s/<\([^ ][^ ]* *\)19 /<\1RK_PC3 /g
s/<\([^ ][^ ]* *\)20 /<\1RK_PC4 /g
s/<\([^ ][^ ]* *\)21 /<\1RK_PC5 /g
s/<\([^ ][^ ]* *\)22 /<\1RK_PC6 /g
s/<\([^ ][^ ]* *\)23 /<\1RK_PC7 /g
s/<\([^ ][^ ]* *\)24 /<\1RK_PD0 /g
s/<\([^ ][^ ]* *\)25 /<\1RK_PD1 /g
s/<\([^ ][^ ]* *\)26 /<\1RK_PD2 /g
s/<\([^ ][^ ]* *\)27 /<\1RK_PD3 /g
s/<\([^ ][^ ]* *\)28 /<\1RK_PD4 /g
s/<\([^ ][^ ]* *\)29 /<\1RK_PD5 /g
s/<\([^ ][^ ]* *\)30 /<\1RK_PD6 /g
s/<\([^ ][^ ]* *\)31 /<\1RK_PD7 /g
s/<\([^ ][^ ]* *[^ ][^ ]* *\)0 /<\1RK_FUNC_GPIO /g
s/<\([^ ][^ ]* *[^ ][^ ]* *\)RK_FUNC_\([1-9]\) /<\1\2 /g
dtsi files
In order to sync rk3288.dtsi from Linux it needed to
move all u-boot specific properties in separate dtsi files.
In order to update the DT for rk3288
sync the power domain dt-binding header.
This is the state as of v5.17 in Linux.
Change location to be more in line with other SoCs.
rk3288 and rk3288w have a usb host0 ohci controller.
Although rk3288 ohci doesn't actually work on hardware, but
rk3288w ohci can work well.
So add usb host0 ohci node in rk3288 dtsi and the quirk in
ohci platform driver will disable ohci on rk3288.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
This sync has changes required to use HDMI CEC pin in U-Boot.
Sync dts from linux v5.8-rc5 commit:
"ARM: dts: rockchip: define the two possible rk3288 CEC pins"
(sha1: 838980dd04e994bf81cf104fa01ae60802146b39)
Signed-off-by: Suniel Mahesh <sunil@amarulasolutions.com>
Reviewed-by: Kever Yang<kever.yang@rock-chips.com>
Move all the tag "u-boot,dm-pre-reloc" from rk3288.dtsi
into rk3288-u-boot.dtsi.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Jerry uses a max98090 audio codec and the internal SoC I2S peripheral.
Enable sound support and add the required device-tree pieces.
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Fix warning below:
unnecessary #address-cells/#size-cells without "ranges" or child "reg"
property
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
The LCDC assigned rate is 0, it will make boot error,
error log:"pll_para_config: the frequency can not be
0 Hz". Remove them, and the lcdc driver will do the
correct clock rate setting.
Signed-off-by: David Wu <david.wu@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Since the 'clock-freq-min-max' is deprecated, we use max-frequency.
Add mipi dsi configuration for evb-rk3288 device tree.
Signed-off-by: Eric Gao <eric.gao@rock-chips.com>
Enable fastboot feature on rk3288.
This path doesn't support the fastboot flash function command entirely.
We will hit "cannot find partition" assertion without specified
partition environment. Define gpt partition layout in specified board
such as firefly-rk3288, then enjoy it!
Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com>
Add these node to be used in rockchip LVDS and VOP driver.
Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
This has been added and we have references to it in the rock2 board. Add
this node.
Enable these devices using the VOPL video output device. We explicitly
disable VOPB in the device tree to avoid it taking over. Since this device
has an LCD display this comes up by default. If the display fails for some
reason then it will attempt to use HDMI. It is possible to force it to fail
(and thus fall back to HDMI) by puting 'return -EPERM' at the top of
rk_edp_probe(). For now there is no easy way to select between the two.
Unify serial_rockchip, and use the generic binding.
Tested-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar>
In SPL we need access to the CRU and other peripherals so we can set up
SDRAM. Mark these so that they will remain in the device tree.
Bring in required device tree files from Linux. Since mainline Linux is
somewhat behind, use the files from the Chromium tree. We can re-sync once
further code is acccepted upstream.
