path: root/arch/arm/dts/rk3288-veyron-chromebook.dtsi
2016-11-25rockchip: video: Check for device in useSimon Glass
Check whether a display device is in use before using it. Add a comment as to why two displays cannot currently be used at the same time. This allows us to remove the device-tree change that disables vopb on jerry. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: jerry: Enable the Chrome OS ECSimon Glass
Turn on the EC and enable the keyboard. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add basic support for jerrySimon Glass
This builds and displays an SPL message, but does not function beyond that. Signed-off-by: Simon Glass <sjg@chromium.org>
