path: root/arch/arm/dts/rk3128.dtsi
2022-12-19arm: dts: rockchip: rk3128: fix clocks, compatible and physJohan Jonker
Fix rk3128 clocks, compatible and phys, so that they match the bindings. Signed-off-by: Johan Jonker <jbx6244@gmail.com>
2022-12-19arm: dts: rockchip: rk3128: fix DT node namesJohan Jonker
The rk3128 DT node names should be generic. Rename them to the pattern defined in the DT bindings. Signed-off-by: Johan Jonker <jbx6244@gmail.com>
2022-12-19arm: dts: rockchip: move all rk3128 u-boot specific properties in separate ↵Johan Jonker
dtsi files Move all rk3128 u-boot specific properties in separate dtsi files. Sort emmc node. Signed-off-by: Johan Jonker <jbx6244@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2022-12-19arm: dts: rockchip: rk3128: bulk convert gpios to their constant counterpartsJohan Jonker
Bulk convert rk3128 DT gpios to their constant counterparts. sed -i -f script.sed rk3128.dtsi sed -i -f script.sed rk3128-evb.dts ================================ /rockchip,pins *=/bcheck b # to end of script :append-next-line N :check /^[^;]*$/bappend-next-line s/<RK_GPIO\([0-9]\) /<\1 /g s/<\([^ ][^ ]* *\)0 /<\1RK_PA0 /g s/<\([^ ][^ ]* *\)1 /<\1RK_PA1 /g s/<\([^ ][^ ]* *\)2 /<\1RK_PA2 /g s/<\([^ ][^ ]* *\)3 /<\1RK_PA3 /g s/<\([^ ][^ ]* *\)4 /<\1RK_PA4 /g s/<\([^ ][^ ]* *\)5 /<\1RK_PA5 /g s/<\([^ ][^ ]* *\)6 /<\1RK_PA6 /g s/<\([^ ][^ ]* *\)7 /<\1RK_PA7 /g s/<\([^ ][^ ]* *\)8 /<\1RK_PB0 /g s/<\([^ ][^ ]* *\)9 /<\1RK_PB1 /g s/<\([^ ][^ ]* *\)10 /<\1RK_PB2 /g s/<\([^ ][^ ]* *\)11 /<\1RK_PB3 /g s/<\([^ ][^ ]* *\)12 /<\1RK_PB4 /g s/<\([^ ][^ ]* *\)13 /<\1RK_PB5 /g s/<\([^ ][^ ]* *\)14 /<\1RK_PB6 /g s/<\([^ ][^ ]* *\)15 /<\1RK_PB7 /g s/<\([^ ][^ ]* *\)16 /<\1RK_PC0 /g s/<\([^ ][^ ]* *\)17 /<\1RK_PC1 /g s/<\([^ ][^ ]* *\)18 /<\1RK_PC2 /g s/<\([^ ][^ ]* *\)19 /<\1RK_PC3 /g s/<\([^ ][^ ]* *\)20 /<\1RK_PC4 /g s/<\([^ ][^ ]* *\)21 /<\1RK_PC5 /g s/<\([^ ][^ ]* *\)22 /<\1RK_PC6 /g s/<\([^ ][^ ]* *\)23 /<\1RK_PC7 /g s/<\([^ ][^ ]* *\)24 /<\1RK_PD0 /g s/<\([^ ][^ ]* *\)25 /<\1RK_PD1 /g s/<\([^ ][^ ]* *\)26 /<\1RK_PD2 /g s/<\([^ ][^ ]* *\)27 /<\1RK_PD3 /g s/<\([^ ][^ ]* *\)28 /<\1RK_PD4 /g s/<\([^ ][^ ]* *\)29 /<\1RK_PD5 /g s/<\([^ ][^ ]* *\)30 /<\1RK_PD6 /g s/<\([^ ][^ ]* *\)31 /<\1RK_PD7 /g s/<\([^ ][^ ]* *[^ ][^ ]* *\)0 /<\1RK_FUNC_GPIO /g s/<\([^ ][^ ]* *[^ ][^ ]* *\)RK_FUNC_\([1-9]\) /<\1\2 /g Signed-off-by: Johan Jonker <jbx6244@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2022-12-19rockchip: rk3128-cru: sync the clock dt-binding header from LinuxJohan Jonker
In order to update the DT for rk3128 sync the clock dt-binding header. This is the state as of v6.0 in Linux. Signed-off-by: Johan Jonker <jbx6244@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2018-01-28rockchip: dts: rk3128: update pwm-cell for pwm0Kever Yang
The backlight pwm-cell is 3. This remove the warning in buildman: arch/arm/dts/rk3126-evb.dtb: Warning (pwms_property): Property 'pwms', cell 3 is not a phandle reference in /backlight arch/arm/dts/rk3126-evb.dtb: Warning (pwms_property): Missing property '#pwm-cells' in node /sram@10080400 or bad phandle (referred from /backlight:pwms[3]) Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-30rockchip: rk3128: add device tree fileKever Yang
Add dts binding header for rk3128, files origin from kernel. Series-Changes: 2 - fix i2c address - add saradc and usb phy node - emmc using fifo mode for there is no dma support in rk3128 emmc - add some clock id in cru.h Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
