path: root/arch/arm/dts/r8a77970-u-boot.dtsi
2019-04-09ARM: dts: rmobile: Synchronize Gen3 DTs with Linux 5.0Marek Vasut
Synchronize R-Car Gen3 device trees with Linux 5.0, commit 1c163f4c7b3f621efff9b28a47abb36f7378d783 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-12-04ARM: dts: rmobile: Extract RPC node to u-boot specific DTMarek Vasut
The RPC DT bindings are still work in progress. Extract the RPC DT node from the DT to allow easier update and so it can be replaced once the DT bindings are stable. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> --- V2: Rebase on u-boot/master
2018-01-24ARM: dts: rmobile: Factor out U-Boot extrasMarek Vasut
Pull out u-boot extras into dtsi files to make synchronization of DTS from Linux kernel as easy as a simple copy. All the U-Boot extras are now in *-u-boot.dts* files instead. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
