path: root/arch/arm/dts/r8a77970-eagle.dts
2018-12-04ARM: dts: rmobile: Sync Gen3 DTs with Linux 4.19.6Marek Vasut
Synchronize DTs with mainline Linux 4.19.6 , commit 96db90800c06d3fe3fa08eb6222fe201286bb778 Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> --- V2: Rebase on u-boot/master
2018-12-04ARM: dts: rmobile: Extract AVB node extras on V3M EagleMarek Vasut
The AVB node is not complete in Linux 4.17 DTs on V3M Eagle, pull the AVB node extras into U-Boot specific DT until they hit mainline Linux, to make syncing of DTs easier. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> --- V2: Rebase on u-boot/master
2018-12-04ARM: dts: rmobile: Extract RPC node to u-boot specific DTMarek Vasut
The RPC DT bindings are still work in progress. Extract the RPC DT node from the DT to allow easier update and so it can be replaced once the DT bindings are stable. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> --- V2: Rebase on u-boot/master
2018-06-19ARM: dts: rmobile: Move the PHY reset GPIOs into PHY nodesMarek Vasut
Both the RAVB and SH ether driver now support parsing the PHY reset GPIOs from both the PHY nodes and the MAC nodes, move the reset GPIOs back into the PHY nodes to minimize DT difference between U-Boot and Linux. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-16ARM: dts: rmobile: Add AVB PHY reset on V3M EagleMarek Vasut
Add EtherAVB PHY reset on V3M Eagle to let the AVB driver unreset the PHY. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-16ARM: dts: rmobile: Add AVB pinmux on V3M EagleMarek Vasut
Add EtherAVB pinmux node on V3M Eagle to set the pinmux configuration. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-14ARM: rmobile: Sync Gen3 DTS with Linux v4.17Marek Vasut
Sync the DTs with Linux v4.17. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-17ARM: rmobile: Enable RPC QSPI on R8A77970 V3M EagleMarek Vasut
Enable the RPC QSPI driver on R8A77970 V3M Eagle and configure the environment layout to match that used by old U-Boot. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24ARM: dts: rmobile: Update DTS to match Linux 4.14Marek Vasut
Import the RCar Gen3 DTS and headers from upstream Linux kernel v4.14, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . This includes both M3 and H3 ULCB and Salvator-X boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-12-09ARM: rmobile: Add R8A77970 V3M Eagle boardMarek Vasut
Add bits to support yet another board, the R8A77970 V3M Eagle. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
