path: root/arch/arm/dts/r8a7795.dtsi
2018-04-17ARM: rmobile: Add Renesas RPC HF/QSPI DT nodesMarek Vasut
Add device tree nodes for the Renesas RPC HF/QSPI controller. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24ARM: dts: rmobile: Factor out U-Boot extrasMarek Vasut
Pull out u-boot extras into dtsi files to make synchronization of DTS from Linux kernel as easy as a simple copy. All the U-Boot extras are now in *-u-boot.dts* files instead. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24ARM: dts: rmobile: Update DTS to match Linux 4.14Marek Vasut
Import the RCar Gen3 DTS and headers from upstream Linux kernel v4.14, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . This includes both M3 and H3 ULCB and Salvator-X boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Use PRR driver on all Gen3 boardsMarek Vasut
Mark the PRR as u-boot,dm-pre-reloc in all Gen3 board DTs as it is needed very early and turn on the CONFIG_SYSCON to allow the PRR driver to bind as a syscon uclass. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-12ARM: dts: rmobile: Update DTS to match Linux 4.13Marek Vasut
Import the RCar Gen3 DTS and headers from upstream Linux kernel v4.13, commit 569dbb88e80deb68974ef6fdd6a13edb9d686261 . This includes both M3 and H3 ULCB and Salvator-X boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-26ARM: rmobile: Add u-boot, dm-pre-reloc to clock nodes on Gen3Marek Vasut
We need the clock available very early, add the u-boot,dm-pre-reloc DT property on those nodes, so they come up very in the process. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-03ARM: dts: rmobile: Import DTS from Linux 4.12Marek Vasut
Import the RCar Gen3 DTS and headers from upstream Linux kernel v4.12-rc6, commit 6f7da290413ba713f0cdd9ff1a2a9bb129ef4f6c . This includes both M3 and H3 ULCB and Salvator-X boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
