path: root/arch/arm/dts/r8a7795.dtsi
2019-04-09ARM: dts: rmobile: Synchronize Gen3 DTs with Linux 5.0Marek Vasut
Synchronize R-Car Gen3 device trees with Linux 5.0, commit 1c163f4c7b3f621efff9b28a47abb36f7378d783 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-12-04ARM: dts: rmobile: Sync Gen3 DTs with Linux 4.19.6Marek Vasut
Synchronize DTs with mainline Linux 4.19.6 , commit 96db90800c06d3fe3fa08eb6222fe201286bb778 Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> --- V2: Rebase on u-boot/master
2018-12-04ARM: dts: rmobile: Extract RPC node to u-boot specific DTMarek Vasut
The RPC DT bindings are still work in progress. Extract the RPC DT node from the DT to allow easier update and so it can be replaced once the DT bindings are stable. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> --- V2: Rebase on u-boot/master
2018-06-14ARM: rmobile: Sync Gen3 DTS with Linux v4.17Marek Vasut
Sync the DTs with Linux v4.17. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-17ARM: rmobile: Add Renesas RPC HF/QSPI DT nodesMarek Vasut
Add device tree nodes for the Renesas RPC HF/QSPI controller. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24ARM: dts: rmobile: Factor out U-Boot extrasMarek Vasut
Pull out u-boot extras into dtsi files to make synchronization of DTS from Linux kernel as easy as a simple copy. All the U-Boot extras are now in *-u-boot.dts* files instead. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24ARM: dts: rmobile: Update DTS to match Linux 4.14Marek Vasut
Import the RCar Gen3 DTS and headers from upstream Linux kernel v4.14, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . This includes both M3 and H3 ULCB and Salvator-X boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Use PRR driver on all Gen3 boardsMarek Vasut
Mark the PRR as u-boot,dm-pre-reloc in all Gen3 board DTs as it is needed very early and turn on the CONFIG_SYSCON to allow the PRR driver to bind as a syscon uclass. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-12ARM: dts: rmobile: Update DTS to match Linux 4.13Marek Vasut
Import the RCar Gen3 DTS and headers from upstream Linux kernel v4.13, commit 569dbb88e80deb68974ef6fdd6a13edb9d686261 . This includes both M3 and H3 ULCB and Salvator-X boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-26ARM: rmobile: Add u-boot, dm-pre-reloc to clock nodes on Gen3Marek Vasut
We need the clock available very early, add the u-boot,dm-pre-reloc DT property on those nodes, so they come up very in the process. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-03ARM: dts: rmobile: Import DTS from Linux 4.12Marek Vasut
Import the RCar Gen3 DTS and headers from upstream Linux kernel v4.12-rc6, commit 6f7da290413ba713f0cdd9ff1a2a9bb129ef4f6c . This includes both M3 and H3 ULCB and Salvator-X boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
