path: root/arch/arm/dts/r8a7792.dtsi
2019-04-09ARM: dts: rmobile: Synchronize Gen2 DTs with Linux 5.0Marek Vasut
Synchronize R-Car Gen2 device trees with Linux 5.0, commit 1c163f4c7b3f621efff9b28a47abb36f7378d783 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-12-04ARM: dts: rmobile: Sync Gen2 DTs with Linux 4.19.6Marek Vasut
Synchronize DTs with mainline Linux 4.19.6 , commit 96db90800c06d3fe3fa08eb6222fe201286bb778 Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> --- V2: Rebase on u-boot/master
2018-06-14ARM: rmobile: Sync Gen2 DTS with Linux v4.17Marek Vasut
Sync the DTs with Linux v4.17. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27ARM: dts: rmobile: Import R8A7792 DTS from Linux 4.15-rc8Marek Vasut
Import the Renesas R8A7792 DTS and headers from upstream Linux kernel v4.15-rc8, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
