Now that Linux has accepted these tags, move the device tree files in
U-Boot over to use them.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
These do not need to be available early on Gen3 , so move them to
the respective DT files.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add U-Boot DT extras for each SoC and board. This marks the required
nodes with u-boot,dm-pre-reloc to start clock and PRR early on while
avoiding modification of the DTs imported from Linux.
