path: root/arch/arm/dts/r8a774c0-cat874.dts
2023-02-02ARM: dts: rmobile: Synchronize DTs with Linux 6.1.7Marek Vasut
Synchronize R-Car device trees with Linux 6.1.7, commit 21e996306a6afaae88295858de0ffb8955173a15 . The following script has been used for the synchronization: $ for i in $(cd arch/arm/dts/ ; ls -1 r8a* | grep -v 'u-boot.dts' ; sed -n '/#include/ s@.*"\(.*\)"@\1@p' $(ls -1 r8a* | grep -v 'u-boot.dts')) ; do if [ -e /linux-2.6/arch/arm64/boot/dts/renesas/$i ] ; then cp /linux-2.6/arch/arm64/boot/dts/renesas/$i arch/arm/dts/ ; elif [ -e /linux-2.6/arch/arm/boot/dts/$i ] ; then cp /linux-2.6/arch/arm/boot/dts/$i arch/arm/dts/ else echo "NOT FOUND: $i" fi done $ git add $( ( cd arch/arm/dts/ ; ls -1 r8a* | grep -v 'u-boot.dts' ; sed -n '/#include/ s@.*"\(.*\)"@\1@p' $(ls -1 r8a* | grep -v 'u-boot.dts')) | tr " " "\n" | sed 's@^@arch/arm/dts/@g' ) Move the include/dt-bindings/{clk,clock}/versaclock.h header used by the renesas boards to match Linux 6.1.y as well. Keep arch/arm/dts/r8a774c0-u-boot.dtsi sdhi3 node as it is now used by the arch/arm/dts/r8a774c0-cat874.dts board. Pick s@spi-flash@flash@ change in arch/arm/dts/r8a779a0-falcon-u-boot.dts from "ARM: dts: Synchronize R-Car V3U DTs with Linux 5.18.3" . Adjust R8A77990 Ebisu CONFIG_SYS_MMC_ENV_DEV from 2 to 0 to reflect the card enumeration in ebisu.dtsi /aliases DT node . Adjust R8A7795 and R8A7796 ULCB CONFIG_SYS_MMC_ENV_DEV from 1 to 0 to reflect the card enumeration in ulcb.dtsi /aliases DT node . Signed-off-by: Marek Vasut <marek.vasut+renesas@mailbox.org> Signed-off-by: Tam Nguyen <tam.nguyen.xa@renesas.com> # r8a779a0-falcon-u-boot.dts Signed-off-by: Hai Pham <hai.pham.ud@renesas.com> # r8a779a0-falcon-u-boot.dts
2021-03-16arm: rmobile: Add Silicon Linux EK874 board supportLad Prabhakar
The EK874 development kit from Silicon Linux is made of CAT874 (the main board) and CAT875 (the sub board that goes on top of CAT874). This patch adds the required board support to boot Si-Linux EK874 board based on R8A774C0 SoC. DTS files apart from r8a774c0-ek874-u-boot.dts and r8a774c0-u-boot.dtsi have been imported from Linux kernel 5.11 commit f40ddce88593 ("Linux 5.11"). Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com>
