path: root/arch/arm/dts/px30-evb-u-boot.dtsi
2020-04-29arm: dts: rockchip: px30: add and enable rng nodeLin Jinhan
Add enable rng node in px30-evb-u-boot.dtsi. Signed-off-by: Lin Jinhan <troy.lin@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-04-28rockchip: px30: add -u-boot dtsi for socKever Yang
Add soc level -u-boot.dtst so that boards can share the common nodes. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-23rockchip: px30: enable spl-fifo-mode for both emmc and sdmmc on evbHeiko Stuebner
As part of loading trustedfirmware, the SPL is required to place portions of code into the socs sram but the mmc controllers can only do dma transfers into the regular memory, not sram. The results of this are not directly visible in u-boot itself, but manifest as security-relate cpu aborts during boot of for example Linux. There were a number of attempts to solve this elegantly but so far discussion is still ongoing, so to make the board at least boot correctly put both mmc controllers into fifo-mode, which also circumvents the issue for now. Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-11-17rockchip: add px30 devicetreesHeiko Stuebner
Add px30 related devicetrees synced from the Linux kernel. Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
