2023-04-14 | arm: dts: omap3x: Update devicetree header comments to sync with v6.3-rc6 | Andrew Davis | |
Signed-off-by: Andrew Davis <afd@ti.com> | |||
2021-09-10 | ARM: dts: Fix node status to "okay" on TI boards | Roger Quadros | |
As per Device Tree Specification [1], the status parameter of nodes can be "okay", "disabled", etc. "ok" is not a valid parameter. U-boot Driver Model does not recognize status="ok" either and treats the node as disabled. [1] https://github.com/devicetree-org/devicetree-specification/releases/tag/v0.3 Signed-off-by: Roger Quadros <rogerq@kernel.org> Reviewed-by: Nishanth Menon <nm@ti.com> | |||
2018-01-01 | ARM: dts: omap3-evm: Add support for TMDSEVM{3530, 3730} | Derald D. Woods | |
This commit adds OMAP3 EVM devicetree files from Linux v4.15-rc3. Note that this is the first addition of OMAP34XX devicetree files. Signed-off-by: Derald D. Woods <woods.technical@gmail.com> |
