path: root/arch/arm/dts/omap3-evm-u-boot.dtsi
2020-08-11ARM: omap3: evm: Complete DM_ETH and DM_USB migrationsDerald D. Woods
This commit completes the migrations for DM_ETH and DM_USB. The board is now consistent with omap3_beagle and other remaining OMAP3 boards. Cc: Tom Rini <trini@konsulko.com> Cc: Adam Ford <aford173@gmail.com> Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
2019-02-19ARM: omap3: evm: Update DM SPL supportDerald D. Woods
- Switch to using the omap3-u-boot.dtsi file for needed properties - Enable SPL_OF_CONTROL This commit is based on the following series: https://patchwork.ozlabs.org/project/uboot/list/?series=92472 https://patchwork.ozlabs.org/project/uboot/list/?series=92462 Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-09-29ARM: DTS: various omap3: Remove cd-inverted from u-boot.dtsiAdam Ford
With the omap_mmc driver no longer supporting cd-inverted, this patch removes all these references since they are not needed. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-01ARM: dts: omap3-evm: Add support for TMDSEVM{3530, 3730}Derald D. Woods
This commit adds OMAP3 EVM devicetree files from Linux v4.15-rc3. Note that this is the first addition of OMAP34XX devicetree files. Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
