path: root/arch/arm/dts/meson-gxm-khadas-vim2.dts
2019-01-31arm64: dts: meson-gx: Add hdmi_5v regulator as hdmi tx supplyNeil Armstrong
The hdmi_5v regulator must be enabled to provide power to the physical HDMI PHY and enables the HDMI 5V presence loopback for the monitor. Fixes: b409f625a6d5 ("ARM64: dts: meson-gx: Add HDMI_5V regulator on selected boards") Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Kevin Hilman <khilman@baylibre.com> [backport of linux commit e1f2163deac059ad39f07aba9e314ebe605d5a7a]
2018-12-03ARM: meson: Add regmap support for clock driverLoic Devulder
This patch modifies the meson clock driver to use syscon/regmap like the Linux kernel does, as it is needed if we want to share the same DTS files. DTS files are synchronized from Linux 4.19. Signed-off-by: Loic Devulder <ldevulder@suse.de> Acked-by: Neil Armstrong <narmstrong@baylibre.com>
2018-10-10ARM: meson: Add Khadas VIM2 board DTLoic Devulder
This adds Device Tree for the Khadas VIM2 board. The meson-gxm-khadas-vim2.dts is synchronized from Linux 4.18.10. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Loic Devulder <ldevulder@suse.de> Acked-by: Neil Armstrong <narmstrong@baylibre.com>
