path: root/arch/arm/dts/meson-gxbb.dtsi
2018-12-03ARM: meson: Add regmap support for clock driverLoic Devulder
This patch modifies the meson clock driver to use syscon/regmap like the Linux kernel does, as it is needed if we want to share the same DTS files. DTS files are synchronized from Linux 4.19. Signed-off-by: Loic Devulder <ldevulder@suse.de> Acked-by: Neil Armstrong <narmstrong@baylibre.com>
2018-06-13ARM64: meson: Sync DT with Linux 4.17Neil Armstrong
Synchronize the Linux Device Tree for Amlogic Meson GX boards from Linux 4.17.0 This will enable USB on Amlogic Meson GXL Boards like Khadas VIM, P212 or LibreTech-CC. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-05-08ARM64: meson: Sync DT and Bindings with Linux 4.16Neil Armstrong
Synchronize the Linux Device Tree for Amlogic Meson GX boards from Linux 4.16.0. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2017-11-17ARM: dts: Synchronize Amlogic from Linux Mainline 4.13.5Neil Armstrong
Synchronize the Amlogic ARM64 dts from mainline Linux 4.13.5 In the preparation of the support of the Amlogic P212 board, import the corresponding meson-gxl-s905x-p212.dts file. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Beniamino Galvani <b.galvani@gmail.com>
2017-07-26arm: dts: meson: import dts files from Linux 4.12Beniamino Galvani
Import Amlogic Meson DTS files from Linux kernel version 4.12 Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-14arm: dts: update Meson GXBB / Odroid-C2 DT with recent Linux versionHeiner Kallweit
As a prerequisite for adding a Meson GX MMC driver update the Meson GXBB / Odroid-C2 device tree in Uboot with the latest version from Linux. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Carlo Caione <carlo@endlessm.com> Signed-off-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
2016-09-06arm: dts: update DTS files for meson-gxbb and odroid-c2Beniamino Galvani
Import DTS files and dt-bindings includes from Linux 4.8-rc1. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-27arm: add initial support for Amlogic Meson and ODROID-C2Beniamino Galvani
This adds platform code for the Amlogic Meson GXBaby (S905) SoC and a board definition for ODROID-C2. This initial submission only supports UART and Ethernet (through the existing Designware driver). DTS files are the ones submitted to Linux arm-soc for 4.7 [1]. [1] https://patchwork.ozlabs.org/patch/603583/ Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
