path: root/arch/arm/dts/ls1021a.dtsi
2017-01-18arm: ls1021a: add PCIe dts nodeMinghuan Lian
Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-12-05ls1021a: QSPI: update the node for QSPI supportYuan Yao
Add the name for register space and memory space. <0x1550000 0x10000 > is the QSPI register space. <0x40000000 0x4000000> is the QSPI memory space. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-08-07dm: ls1021a: dts: Update USB 3.0 node to support DM USBRajesh Bhagat
Update USB 3.0 controller dts node in ls1021a.dtsi. Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2016-01-20arm: ls1021atwr: Convert to driver model and enable serial supportBin Meng
Convert ls1021atwr_nor to driver model support. As a start, enable ns16550 serial port driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: ls1021a: dts: Add QSPI dts nodeHaikun.Wang@freescale.com
Add QSPI controller dts node in ls1021a.dtsi. Add QSPI slave device dts node in ls1021a-twr.dts and ls1021a-qds.dts. Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: ls1021a: dts: Update DSPI node to support DM SPIHaikun.Wang@freescale.com
Update DSPI controller node in ls1021a.dtsi. Update flash device node in ls1021a-qds.dts. Ls1021a-twr board doesn't support DSPI, so remove DSPI node in ls1021a-twr.dts. Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: ls1021a: dts: Change address_cells and size_cells from 2 to 1haikun
Change address_cells and size_cells of root node and 'soc' node from 2 to 1. We backport ls1021a device tree source files from kernel to u-boot. Kernel files set address_cells and size_cells to 2 in order to access more than 4GB space. But we don't have this requirement now and u-boot fdtdec_get_xxx interfaces can't support property whose size is 'u64' completely. So make this change. Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: ls1021a: Bring in ls1021a dts files from linux kernelhaikun
Bring in required device tree files for ls1021a from Linux. These are initially unchanged and have a number of pieces not needed by U-Boot. Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
