path: root/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi
2019-02-19ARM: omap3_logic: Enable SPL booting device treeAdam Ford
With the generic omap3-u-boot.dtsi file available, this patch increased the memory of the various incarnations of the omap3_logic board, and points their respective u-boot.dtsi files to the newly created generic one, and removes the PLATDATA from the board file. These are all done at once because the're all utilizing the same omap3logic.c board file. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-10-06ARM: DTS: Add Logic PD OMAP35/DM37 SOM-LV and OMAP35 TorpedoAdam Ford
With the device trees doing most of the work of pin-muxing and DM doing much of the peripheral initialization, this creates new defconfig files for each of the Logic PD variants with proper register settings/pin-muxing. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Update MAINTAINERS entry] Signed-off-by: Tom Rini <trini@konsulko.com>
