path: root/arch/arm/dts/kirkwood-db-88f6281-spi.dts
2019-04-26ARM: kirkwood: add db-88f6281-bp boardChris Packham
This is Marvell's Kirkwood development board. It has the following features - 512M DDR2 - 2 PCI connectors - 1 x1 PCI-e interface - 1 Gigabit Ethernet Port - 2 SATA Ports - USB 2.0 Interface - SDIO - 128M NAND Flash - 16M SPI Flash It can be strapped to boot from SPI or NAND so there are two defconfigs (one per boot media). Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
