This is a collection of all the whitespace, renames, comment, and other
changes that should not change the DT functionality from Linux v6.3-rc6.
Signed-off-by: Andrew Davis <afd@ti.com>
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Linux uses "cdns,qspi-nor" as compatible string for the cadence
qspi driver, so change driver, docs and all device trees.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Adopt the Linux DT bindings and clean-up duplicate
and unused values.
Fix indentation of the QSPI node in the keystone k2g
device tree.
Tested on TI K2G platform:
Tested-by: Vignesh R <vigneshr@ti.com>
Tested on a socfpga-cyclonev board:
Tested-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Signed-off-by: Jason Rush <jarush@gmail.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Acked-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Upstream Linux has the unit address being added to the various 66AK2Gx
boards dts. Therefore, update the dts to mimic this change.
Also remove memory node from the base K2G dtsi file.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Adding the unit address to the memory node was causing the below error:
Warning (reg_format): "reg" property in /memory has invalid length
(8 bytes) (#address-cells == 2, #size-cells == 2)
Further debugging showed that this was due to the memory node added by
default to skeleton.dtsi which was being included in keystone-k2g.dtsi.
Adding a missing node was all that was needed to remove this deprecated
dtsi file from the SoC dtsi. With skeleton.dtsi removed the dtc compiler
no longer complained about including the unit address for the memory node.
Add I2C nodes to the 66AK2Gx dtsi.
As reported in [1], rename the k2* dts files to keystone-* files
this will force consistency throughout.
Script for the same (and hand modified for Makefile and config
files):
for i in arch/arm/dts/k2*
do
b=`basename $i`;
git mv $i arch/arm/dts/keystone-$b;
sed -i -e "s/$b/keystone-$b/g" arch/arm/dts/*[si]
done
This is similar to linux kernel commit 5edafc29829bc ("ARM: dts: k2*: Rename
the k2* files to keystone-k2* files")
[1] http://marc.info/?l=linux-arm-kernel&m=145637407804754&w=2
